SketchUp 2027 – Default Tray Settings Not Retained After Restart
SketchUp 2027 Issue: The Default Tray does not retain its settings. Every time I open SketchUp, the tray details are missing, and I have to set them up again. Does anyone else have the same problem?
If you are on a PC it suggested you have not installed SketchUp with the proper permissions, so it cannot save defaults etc…
You do not need to reinstall it, here are the steps to fix permissions…
Log in as your usual user-account.
Close SketchUp if it’s open.
Find the installer exe file - usually in your Downloads folder.
Select its icon and right-click > context-menu > Run as administrator…
When prompted choose ‘Repair’
When it completes, restart SketchUp and test to see if the savings of settings are working as expected.
Running any complex app’s installer exe by double-clicking it to ‘Run’ is NOT the same - even if you have admin powers associated with you user-account it is NOT the same. Weirdness can be unpredictable from ‘nothing noticeable’ to ‘unexpected permission blocks’ on closing etc…
