icon and extension signature are missing, even for Trimble extensions
and when enabling or disenambling an extension, the ‘aplly changes’ button is not active
2026 version 26.1.256 64 bits
is there a solution to these problems?
Specifically:
Make sure you installed SketchUp correctly by right clicking on the downloaded installer and selecting Run as administrator.
Please update your forum profile. It says you are still using SketchUp 2022,
We will have an update that doesn’t show this problem. I can’t yet say when the update will be ready.
In the meantime, the extensions are working ok. The extension manager window looks broken when you are running SketchUp in something other than English. If you are able to run SketchUp in English, you could do that long enough to enable or disable extensions. Or you could manually go into the Plugins folder to add or remove extensions.
OK
since the extensions work, i shall wait for an update
thank you
