Hello, I need help diagnosing SketchUp 2026 startup failure.
Environment: Windows 11; SketchUp 26.2.243.76 (official Trimble-signed installer, active trial); NVIDIA GeForce GT 730, driver 388.13; approximately 32 GB RAM. An Oray virtual display adapter is also present.
Symptoms: The Welcome screen opens. Selecting the Simple / Meters template closes the Welcome screen, but no modeling window appears. A diagnostic launch using an original template bundled with SketchUp exits after a few seconds with exit code 1. This is not specific to a project file.
Tests completed, without resolving the problem:
- Repair installation using the official installer.
- Classic graphics engine; explicit GPU selection; anti-aliasing and Fast Feedback disabled for testing.
- Extension enable flags disabled, followed by full temporary isolation of both the user Plugins and installation ShippedExtensions folders. Original folders were restored afterwards.
- SU_CEF_DISABLE_GPU=1, including a launch with this variable explicitly supplied to the process.
- Backing up and temporarily clearing toolbar layout state so it could rebuild; original state then restored.
Graphics diagnostics identify the GT 730 and OpenGL 4.6.0 NVIDIA 388.13, and report that initial graphics validation completed. This does not rule out a later graphics issue. Visual C++ v14 x64 and x86 runtime installation records show 14.51.36247.
Older failures recorded ucrtbase.dll / 0xc0000409 and a separate SketchUp.exe / 0xc0000005 crash. The later reproducible exit code 1 may be a different failure, so I am not treating these as one confirmed cause.
What safe diagnostic step would help identify why it exits at this stage? Is there a known issue affecting this version after the Welcome screen? I have not attached full logs, crash dumps, account details, or project files. Thank you.
