For the four recent bugsplats you sent in, you have 79 extensions that load. None of them look like that one.
The crash happens while Componentes dinámicos (Dynamic Components) is loading. I wonder if extension migrator brought in an old version of some extensions, that are causing a problem.
I disabled dynamic components but I still get the crashes, there’s always one plugin that causes the crashes. I wonder why is that happening, since the release of 2026 until a few weeks ago I had no issues. On Mac I have the same plugins and no crashes, I haven’t updated windows, but the gpu drivers are up to date, I don’t want to update windows cause there’s a known issue with the latest version, anyways I don’t think that updating would solve the problem.
I fixed the problem, I used Revo uninstaller to delete every trace of all the sketchup version I have installed on my pc since 2023, there were not trace of sketchup on my pc. Then I installed Sketchup 2026, Of course I had to install all the Plugins I use, It took me awhile but everything was perfect, no crashes at opening, then I installed the drivers for the 3D mouse and the crashes return, I uninstalled and the problem went away. I´m happy because I can use sketchup 2026 without any issues, but on the other hand im used to work with my space mouse and its cumbersome not being able to use it. Does anyone else has the same issue, I have no issues with curic´s plugins by the way, just 3Dxware.
Happiness lasted few minutes. I instaled the latest SketchUp update and I can’t open anymore sketchup 2026, @colin I sent some bugsplats, can you tell me why were does crashes happening?
