Hi @AlejandroGA . No worries and I understand. I was curious if you followed the thread and tried to use the classic graphics if that would also help you. It would be more weight to show the need for a bug fix on the new graphics engine.
Version 24 uses the ‘new’ graphics engine by default and I have seen a crash too. The thread that I jumped into was started by somebody who also found a crash specific to version 24. I happened to verify that the crashes would stop if going back to the same graphics engine used in version 23, which is called the classic graphics engine now. I further happened to discover that the window size has something to do with it.
I know that not every system is the same, but I’m also using An M2 Mac on Sonoma 14.4.1. The odds are fairly good that if you change to the classic engine, the crash might stop.
Click the ‘Sketchup’ menu and select settings.
Then click ‘Graphics’ on the window that appears.
Change the radio button from new to classic graphics engine.
Close the windows, then quit sketchup and re-open it to be sure the settings persisted (see image).
