Sketchup 2023 Won't Download
I get this error every time I try to install sketchup, or open a file.
I can give more info if you need it, but please help!
Perhaps you can try download and install the Offline “Windows installer” from:
https://www.sketchup.com/offline-download
Hi, thanks for helping.
So I tried that but it gave me the same error.
I can open the program, open recent files. But I cannot open a file that I have been working on the most.
So when I try to install I say “Uninstall Previous Versions” and it completes that, but when i get to the Install prompts, it brings up that error.
I have restarted my computer and researched it. But since I don’t exactly know the problem it’s hard to find the solution.
what version of windows are you using?
Version 10.0.22000 Build 22000
Perhaps:
  • Restart your computer (to be sure no SketchUp is running)
  • Open the Windows Control panel, then start the Programs and Features (or Uninstall Program)
  • Locate the SketchUp there and uninstall.
  • When it is done restart computer again.
  • Now try to install SketchUp using the ofline installer in my previous post.
Ok, did that.
Closed Sketchup
Restarted
Apps & Features > Sketchup > Uninstall
Unfortunately this error came up.
Try this Fix problems that block programs from being installed or removed
Locate the above mentioned SketchUp installer file right clink on it and choose Run as administrator…
Same Error.
I was wondering, it says the file SketchUp 2023.msi is not found. How do I get that file?
Here’s a recording.
Videos:
Sketchup Issues
@johannaj
Use this troubleshooter
I use this utility, very handy for finding files:
https://www.voidtools.com/support/everything/
I will suggest to support that they use that too.
Finally - Installed Through (No Errors)
I used this and deleted all files on my computer of sketchup, then I downloaded the installer, used it to uninstall any other files of sketchup, then installed and it worked!!! Thank you!
I searched for and manually removed all mentions of sketchup through the registry, and it worked for me.
