SketchUp 2023.msi missing from AppData
SketchUp 2023.msi missing from AppData, probably deleted by mistake, how can I uninstall it?
I mention I already tried to find the msi in the exe with 7zip and in 2023 version it is missing. I also tried with IObit Uninstaller, but after finished uninstalling it is still in installed apps, cannot be uninstalled or installed from EXE. I have version - SketchUp 2023 v23.0.419.
It tooks me around 5 hours by now fo search for different solutions. I am poorly impressed by the developers.
Thank you!
I mention I already read other solutions by searching for “2023.msi” and no viable solution found for this basic problem.
You might try right-clicking on the downloaded SketchUp file, selecting run as administrator then selecting repair.
I know this is a late response. But, I just wanted to respond in case anyone else has this issue. I had this exact issue. So, I ran the download installation as Administrator, created a new folder and named it SketchUp_Download, and it installed perfectly!
