I have a MacBook Pro (14-inch, 2021 M1) running macOS 13.3.1 where Sketchup pro 2022 won’t start. I’ve already deleted the plist files and reinstalled Sketchup but it won’t start. I also installed Sketchup 2023 but it won’t start either. Does anyone have any tips to solve this problem?
ok, taking a guess here, maybe your macos is configured in the secure mode where you’re supposed to install stuff only from the app store (hahahaha, who does that, seriously?)
instead of double clicking on the app, try right click / open. you should have a message like “oh, are you sure, it could be dangerous!” say yes.
if it works, then the following times, a simple double click will work, you bypassed the security.
you could also check this parameter, in security, scroll down a bit, and make sure you authorise non app store stuff too.
If you open Terminal, which is in Applications/Utilities, you can run SketchUp by pasting in this text:
/Applications/SketchUp\ 2022/SketchUp.app/Contents/MacOS/SketchUp
If you get a message saying it can’t be found, it means you have been running SketchUp from an unusual location. If it is found, it will either run ok, or there may be a message in the Terminal window that gives more clues about why it doesn’t run.
Try that test, and let us know what messages you see in the Terminal window.
I ran the terminal command on my mac and get the following messages in the Terminal window. Can you help me further to solve this problem based on these reports? I have also included a screenshot of what I see when I start my Sketchup.
Last login: Tue May 2 14:57:50 on ttys000
The default interactive shell is now zsh.
To update your account to use zsh, please run chsh -s /bin/zsh.
For more details, please visit Use zsh as the default shell on your Mac - Apple Support.
Prosman-Marc:~ marc$ /Applications/SketchUp\ 2022/SketchUp.app/Contents/MacOS/SketchUp
2023-05-02 15:00:07.512 SketchUp[39735:1313001] Initializing Bugsplat
objc[39735]: Class SkpTimerCaller is implemented in both /Applications/SketchUp 2022/SketchUp.app/Contents/MacOS/SketchUp (0x102d5c2c8) and /Applications/SketchUp 2022/SketchUp.app/Contents/Frameworks/LayOutAPI.framework/Versions/A/Libraries/libSketchUpViewerAPI.dylib (0x12255df38). One of the two will be used. Which one is undefined.
objc[39735]: Class SKTextPath is implemented in both /Applications/SketchUp 2022/SketchUp.app/Contents/MacOS/SketchUp (0x102d5c340) and /Applications/SketchUp 2022/SketchUp.app/Contents/Frameworks/LayOutAPI.framework/Versions/A/Libraries/libSketchUpViewerAPI.dylib (0x12255dfb0). One of the two will be used. Which one is undefined.
objc[39735]: Class SKTextPath is implemented in both /Applications/SketchUp 2022/SketchUp.app/Contents/MacOS/SketchUp (0x102d5c340) and /Applications/SketchUp 2022/SketchUp.app/Contents/Frameworks/SketchUpAPI.framework/Versions/A/SketchUpAPI (0x11660db40). One of the two will be used. Which one is undefined.
2023-05-02 15:00:07.775 SketchUp[39735:1313001] INFO: Start CrashManager processing
2023-05-02 15:00:08.277 SketchUp[39735:1313001] [HockeySDK] -[BITCrashManager invokeDelayedProcessing]/974 [HockeySDK] WARNING: Another exception handler was added. If this invokes any kind exit() after processing the exception, which causes any subsequent error handler not to be invoked, these crashes will NOT be reported to HockeyApp!
[0502/150010.058653:INFO:CONSOLE(4172)] “Error accessing file:///Applications/SketchUp%202022/SketchUp.app/Contents/Resources/welcomescreen/…/en.lproj//welcomescreen/en.json–[object ProgressEvent]”, source: file:///Applications/SketchUp%202022/SketchUp.app/Contents/Resources/welcomescreen/regularlaunchpage.bundle.js (4172)
[0502/150010.058747:INFO:CONSOLE(4357)] “Unable to find resource file for language en”, source: file:///Applications/SketchUp%202022/SketchUp.app/Contents/Resources/welcomescreen/regularlaunchpage.bundle.js (4357)
[0502/150010.058783:INFO:CONSOLE(4358)] “In location file:///Applications/SketchUp%202022/SketchUp.app/Contents/Resources/welcomescreen/…/en.lproj//welcomescreen/en.json”, source: file:///Applications/SketchUp%202022/SketchUp.app/Contents/Resources/welcomescreen/regularlaunchpage.bundle.js (4358)
[0502/150010.074724:INFO:CONSOLE(10397)] “Uncaught (in promise) NavigationDuplicated: Navigating to current location (”/home") is not allowed", source: file:///Applications/SketchUp%202022/SketchUp.app/Contents/Resources/welcomescreen/regularlaunchpage.bundle.js (10397)
UNSUPPORTED (log once): POSSIBLE ISSUE: unit 0 GLD_TEXTURE_INDEX_2D is unloadable and bound to sampler type (Float) - using zero texture because texture unloadable
2023-05-02 15:00:16.059 SketchUp[39735:1313001] Cannot find plugin in /Applications/SketchUp 2022/SketchUp.app/Contents/PlugIns/DEMImporter.plugin
2023-05-02 15:00:16.060 SketchUp[39735:1313001] Cannot find plugin in /Applications/SketchUp 2022/SketchUp.app/Contents/PlugIns/IfcImporter.plugin
2023-05-02 15:00:16.106 SketchUp[39735:1313001] Cannot find plugin in /Applications/SketchUp 2022/SketchUp.app/Contents/PlugIns/IfcExporter.plugin
[0502/150253.774231:INFO:CONSOLE(4172)] “Error accessing file:///Applications/SketchUp%202022/SketchUp.app/Contents/Resources/welcomescreen/…/en.lproj//welcomescreen/en.json–[object ProgressEvent]”, source: file:///Applications/SketchUp%202022/SketchUp.app/Contents/Resources/welcomescreen/regularlaunchpage.bundle.js (4172)
[0502/150253.774341:INFO:CONSOLE(4357)] “Unable to find resource file for language en”, source: file:///Applications/SketchUp%202022/SketchUp.app/Contents/Resources/welcomescreen/regularlaunchpage.bundle.js (4357)
[0502/150253.774380:INFO:CONSOLE(4358)] “In location file:///Applications/SketchUp%202022/SketchUp.app/Contents/Resources/welcomescreen/…/en.lproj//welcomescreen/en.json”, source: file:///Applications/SketchUp%202022/SketchUp.app/Contents/Resources/welcomescreen/regularlaunchpage.bundle.js (4358)
[0502/150253.785304:INFO:CONSOLE(10397)] “Uncaught (in promise) NavigationDuplicated: Navigating to current location (”/home/update") is not allowed", source: file:///Applications/SketchUp%202022/SketchUp.app/Contents/Resources/welcomescreen/regularlaunchpage.bundle.js (10397)
[0502/150323.654168:INFO:CONSOLE(4172)] “Error accessing file:///Applications/SketchUp%202022/SketchUp.app/Contents/Resources/welcomescreen/…/en.lproj//welcomescreen/en.json–[object ProgressEvent]”, source: file:///Applications/SketchUp%202022/SketchUp.app/Contents/Resources/welcomescreen/regularlaunchpage.bundle.js (4172)
[0502/150323.654270:INFO:CONSOLE(4357)] “Unable to find resource file for language en”, source: file:///Applications/SketchUp%202022/SketchUp.app/Contents/Resources/welcomescreen/regularlaunchpage.bundle.js (4357)
[0502/150323.654308:INFO:CONSOLE(4358)] “In location file:///Applications/SketchUp%202022/SketchUp.app/Contents/Resources/welcomescreen/…/en.lproj//welcomescreen/en.json”, source: file:///Applications/SketchUp%202022/SketchUp.app/Contents/Resources/welcomescreen/regularlaunchpage.bundle.js (4358)
[0502/150323.676485:INFO:CONSOLE(10397)] “Uncaught (in promise) NavigationDuplicated: Navigating to current location (”/home") is not allowed", source: file:///Applications/SketchUp%202022/SketchUp.app/Contents/Resources/welcomescreen/regularlaunchpage.bundle.js (10397)
[0502/150427.369260:INFO:CONSOLE(1)] “Munchkin.init(”%s") options: 645-COJ-341 [object Object]“, source: https://extensions.sketchup.com/prod/2023-3-31_21-13-3812c5a0f_frontend/index.bundle.js (1)
[0502/150454.687504:INFO:CONSOLE(22)] “Munchkin.init(”%s”) options: 645-COJ-341 [object Object]“, source: https://munchkin.marketo.net/163/munchkin.js (22)
[0502/150459.426061:INFO:CONSOLE(22)] “Munchkin.init(”%s”) options: 645-COJ-341 [object Object]“, source: https://munchkin.marketo.net/163/munchkin.js (22)
[0502/150502.383304:WARNING:spdy_session.cc(3391)] Received HEADERS for invalid stream 105
[0502/150502.383370:WARNING:spdy_session.cc(3391)] Received HEADERS for invalid stream 107
[0502/150502.391315:WARNING:spdy_session.cc(3391)] Received HEADERS for invalid stream 203
[0502/150502.400592:INFO:CONSOLE(1)] “Munchkin.init(”%s”) options: 645-COJ-341 [object Object]“, source: https://extensions.sketchup.com/prod/2023-3-31_21-13-3812c5a0f_frontend/search.bundle.js (1)
[0502/150508.336349:INFO:CONSOLE(1)] “Munchkin.init(”%s”) options: 645-COJ-341 [object Object]“, source: https://extensions.sketchup.com/prod/2023-3-31_21-13-3812c5a0f_frontend/extension.bundle.js (1)
[0502/150601.890344:INFO:CONSOLE(1)] “Munchkin.init(”%s”) options: 645-COJ-341 [object Object]", source: https://extensions.sketchup.com/prod/2023-3-31_21-13-3812c5a0f_frontend/extension.bundle.js (1)
Some of those errors were unexpected, but I see them as well, except for the Munchkin.init ones. Any idea where those come from?
Even with the errors I do then see the welcome screen and can start a new document. I wonder if the welcome screen cache is messed up.
In Finder, Go menu, Go to Folder, paste in this path:
~/Library/Application Support/SketchUp 2022
Delete any folders in there that start with “WebCache”, then try opening SketchUp normally.
I have no idea what (Munchkin.init) is. I deleted al the (WebCache) folders but that didn’t fix the problem.
hi there. fwiw, i am also experiencing this issue on an Apple M2 Air (running Ventura 13.4).
i’ve had this problem with both 2022 and 2023. using your instructions, colin, i’m able to launch via the terminal. but like the other poster, deleting the WebCache folder doesn’t do anything to alleviate the problem. for now, i’ll just launch via terminal, but would love to know if there’s any other resolution here.
for reference, here’s the code i see when i startup via terminal:
objc[16168]: Class SKTextPath is implemented in both /Applications/SketchUp 2023/SketchUp.app/Contents/Frameworks/SketchUpAPI.framework/Versions/A/SketchUpAPI (0x1076f9a60) and /Applications/SketchUp 2023/SketchUp.app/Contents/MacOS/SketchUp (0x10550ae28). One of the two will be used. Which one is undefined.
2023-05-23 14:04:34.779 SketchUp[16168:353248] Initializing Bugsplat
objc[16168]: Class SkpTimerCaller is implemented in both /Applications/SketchUp 2023/SketchUp.app/Contents/MacOS/SketchUp (0x10550adb0) and /Applications/SketchUp 2023/SketchUp.app/Contents/Frameworks/LayOutAPI.framework/Versions/A/Libraries/libSketchUpViewerAPI.dylib (0x12f6660f0). One of the two will be used. Which one is undefined.
objc[16168]: Class SKTextPath is implemented in both /Applications/SketchUp 2023/SketchUp.app/Contents/Frameworks/SketchUpAPI.framework/Versions/A/SketchUpAPI (0x1076f9a60) and /Applications/SketchUp 2023/SketchUp.app/Contents/Frameworks/LayOutAPI.framework/Versions/A/Libraries/libSketchUpViewerAPI.dylib (0x12f666168). One of the two will be used. Which one is undefined.
2023-05-23 14:04:35.164 SketchUp[16168:353248] INFO: Start CrashManager processing
2023-05-23 14:04:35.665 SketchUp[16168:353248] [HockeySDK] -[BITCrashManager invokeDelayedProcessing]/974 [HockeySDK] WARNING: Another exception handler was added. If this invokes any kind exit() after processing the exception, which causes any subsequent error handler not to be invoked, these crashes will NOT be reported to HockeyApp!
[0523/140437.434403:INFO:CONSOLE(42)] "Error accessing file:///Applications/SketchUp%202023/SketchUp.app/Contents/Resources/welcomescreen/../en.lproj//welcomescreen/en.json--[object ProgressEvent]", source: file:///Applications/SketchUp%202023/SketchUp.app/Contents/Resources/welcomescreen/app.bundle.js (42)
[0523/140437.434486:INFO:CONSOLE(42)] "Unable to find resource file for language en", source: file:///Applications/SketchUp%202023/SketchUp.app/Contents/Resources/welcomescreen/app.bundle.js (42)
[0523/140437.434523:INFO:CONSOLE(42)] "In location file:///Applications/SketchUp%202023/SketchUp.app/Contents/Resources/welcomescreen/../en.lproj//welcomescreen/en.json", source: file:///Applications/SketchUp%202023/SketchUp.app/Contents/Resources/welcomescreen/app.bundle.js (42)
[0523/140437.452109:INFO:CONSOLE(42)] "NavigationDuplicated: Avoided redundant navigation to current location: "/home".", source: file:///Applications/SketchUp%202023/SketchUp.app/Contents/Resources/welcomescreen/app.bundle.js (42)
