I noticed a significant performance difference between sketchup 2015 and 2016 regarding material changes in ruby.
This code will perform way faster in 2015 than 2016
Sorry for late answer.
Yes i did run some tests, and with the exact same model and script, 2016 will perform approximately 6 times slower than sketchup 2015.
To test, you just need to select a bunch of faces and edges, and run the function. I did my test on a sphere with 200 faces. It will take 0.38s in 2015 and 2.14s in 2016.
The second flag will disable the UI from updating between the start and commit. The only reason this isn’t true by default is for backwards compatibility. But in reality you should always do this - as otherwise SU will try to refresh everything you make a model change. It might very well be that the UI changes in SU2016 made refreshing the UI perform differently, but it might not be an issue if you make sure to disable it while you modify the model.
Yes i already tried that, it makes a difference, but i notice weird behaviour/crashes in my plugin when i start using those start_operation.
Finally i found out this is caused by the new ‘Default Tray’ in sketchup, it shows by default a lot of tabs that are probably refreshed everytime a script changes something. If i hide the tray, the performance is good again …
After a bit more digging, it turns out this is caused by the Statistics section inside the components tab, as soon as i remove it from the visible UI, everything is back to normal.
However, this very same tab does not cause the same issue in sketchup 2015 and earlier, it refreshes way faster.
This would be worth looking into. Wrapping model changes in start_operation is something one should always do when making bulk changes. It’s a big UX problem to not be able to undo an action in one step. The Extension Warehouse moderation will actually reject extensions because of this. Maybe start a new thread on this topic so we can follow up?
That’s an interesting observation. It could be that the new trays sends more update notifications to that module than what it previously did.
Thanks for your answer, i will look into that, i have a pretty complex ‘observer’ mechanism in place, and it does not play well with undos. I will continue experimenting.
