Sketchup 18 crashed when opening
Hi,
My sketchup 18 crashes when I open the program and click start using sketchup. I can’t do anything in the program and I have a deadline this week.
I think the issue started when I ironically downloaded a bug zapper lamp from the 3d warehouse and opened the file… Since then I can use sketchup. I’ve deleted sketchup and reinstalled it, I’ve deleted all my files, I’ve turned off reopen pages in my Mac general settings, I’ve tried deleting .Plist files and renaming plugin folder but nothing works!
~ user$ /Applications/SketchUp\ 2018/SketchUp.app/Contents/MacOS/SketchUp ; exit;
2018-11-26 08:37:32.122 SketchUp[4669:373535] BugSplatFramework: initWithDatabase: defaultExceptionHandler is set
objc[4669]: Class SKTextPath is implemented in both /Applications/SketchUp 2018/SketchUp.app/Contents/MacOS/SketchUp (0x1024b0378) and /Applications/SketchUp 2018/SketchUp.app/Contents/Frameworks/libSketchUpViewerAPI.dylib (0x1130566f0). One of the two will be used. Which one is undefined.
objc[4669]: Class SkpTimerCaller is implemented in both /Applications/SketchUp 2018/SketchUp.app/Contents/MacOS/SketchUp (0x1024b0300) and /Applications/SketchUp 2018/SketchUp.app/Contents/Frameworks/libSketchUpViewerAPI.dylib (0x113056718). One of the two will be used. Which one is undefined.
objc[4669]: Class SKTextPath is implemented in both /Applications/SketchUp 2018/SketchUp.app/Contents/MacOS/SketchUp (0x1024b0378) and /Applications/SketchUp 2018/SketchUp.app/Contents/Frameworks/SketchUpAPI.framework/Versions/A/SketchUpAPI (0x112a37cf0). One of the two will be used. Which one is undefined.
objc[4669]: Class HLRExporterBase is implemented in both /Applications/SketchUp 2018/SketchUp.app/Contents/PlugIns/Skp2AcadSection.plugin/Contents/MacOS/Skp2AcadSection (0x11f0a6db8) and /Applications/SketchUp 2018/SketchUp.app/Contents/PlugIns/Skp2AcadHlr.plugin/Contents/MacOS/Skp2AcadHlr (0x11f222d30). One of the two will be used. Which one is undefined.
2018-11-26 08:37:51.847 SketchUp[4669:373535] BugSplatFramework: exceptionHandler: shouldLogException name: NSInvalidArgumentException
reason: *** -[__NSArrayM insertObject:atIndex:]: object cannot be nil
mask: 256
2018-11-26 08:37:51.847 SketchUp[4669:373535] NSExceptionHandler has recorded the following exception:
NSInvalidArgumentException – *** -[__NSArrayM insertObject:atIndex:]: object cannot be nil
Stack trace: 0x7fff558d7b27 0x7fff7ab25c76 0x7fff538e74c4 0x7fff537c4730 0x7fff50deb216 0x7fff50deaf92 0x7fff50deace2 0x7fff51277dcc 0x101e0acbc 0x101e09d20 0x7fff51668f29 0x7fff50f0173c 0x7fff50f49b52 0x7fff50f4a01f 0x7fff50f4a01f 0x7fff50f4a01f 0x7fff50f4a01f 0x7fff50f4a01f 0x7fff50f4a01f 0x7fff50f4a01f 0x7fff50f4a01f 0x7fff50f4a01f 0x7fff50f4a01f 0x7fff50eff656 0x7fff50efeddb 0x7fff5166a4e0 0x7fff50efde5d 0x7fff50efa0b4 0x7fff50ef9a52 0x7fff5169a60d 0x7fff50ef955e 0x7fff5eb92817 0x7fff5eb912e9 0x7fff516b1a72 0x7fff5383e2f7 0x7fff5383e21f 0x7fff53820798 0x7fff53820033 0x7fff52b0ad96 0x7fff52b0aa0f 0x7fff52b0a884 0x7fff50dbaa73 0x7fff51550e34 0x7fff50daf885 0x7fff50d7ea72 0x101db0432 0x7fff7b73f015 0x1
2018-11-26 08:37:51.847 SketchUp[4669:373535] BugSplatFramework: exceptionHandler: shouldHandleException name: NSInvalidArgumentException
mask: 512
2018-11-26 08:37:51.847 SketchUp[4669:373535] NSColorList could not parse color list file /Users/user/Library/Colors/Unnamed.clr
2018-11-26 08:37:51.848 SketchUp[4669:373535] BugSplatFramework: exceptionHandler: shouldLogException name: NSRangeException
reason: *** -[__NSArrayM objectAtIndex:]: index 0 beyond bounds for empty array
mask: 256
2018-11-26 08:37:51.848 SketchUp[4669:373535] NSExceptionHandler has recorded the following exception:
NSRangeException – *** -[__NSArrayM objectAtIndex:]: index 0 beyond bounds for empty array
Stack trace: 0x7fff558d7b27 0x7fff7ab25c76 0x7fff538e74c4 0x7fff537c52e4 0x7fff50deab01 0x101e0ad69 0x101e09d20 0x7fff51668f29 0x7fff50f0173c 0x7fff50f49b52 0x7fff50f4a01f 0x7fff50f4a01f 0x7fff50f4a01f 0x7fff50f4a01f 0x7fff50f4a01f 0x7fff50f4a01f 0x7fff50f4a01f 0x7fff50f4a01f 0x7fff50f4a01f 0x7fff50f4a01f 0x7fff50eff656 0x7fff50efeddb 0x7fff5166a4e0 0x7fff50efde5d 0x7fff50efa0b4 0x7fff50ef9a52 0x7fff5169a60d 0x7fff50ef955e 0x7fff5eb92817 0x7fff5eb912e9 0x7fff516b1a72 0x7fff5383e2f7 0x7fff5383e21f 0x7fff53820798 0x7fff53820033 0x7fff52b0ad96 0x7fff52b0aa0f 0x7fff52b0a884 0x7fff50dbaa73 0x7fff51550e34 0x7fff50daf885 0x7fff50d7ea72 0x101db0432 0x7fff7b73f015 0x1
2018-11-26 08:37:51.848 SketchUp[4669:373535] BugSplatFramework: exceptionHandler: shouldHandleException name: NSRangeException
mask: 512
2018-11-26 08:37:51.852 SketchUp[4669:373535] BugSplatFramework: exceptionHandler: shouldLogException name: NSUncaughtSystemExceptionException
reason: Uncaught system exception: signal 4
mask: 4
2018-11-26 08:37:51.852 SketchUp[4669:373535] NSExceptionHandler has recorded the following exception:
NSUncaughtSystemExceptionException – Uncaught system exception: signal 4
Stack trace: 0x7fff558d7c9d 0x7fff7ba4df5a 0x8000100 0x7fff516b1cb1 0x7fff5383e2f7 0x7fff5383e21f 0x7fff53820798 0x7fff53820033 0x7fff52b0ad96 0x7fff52b0aa0f 0x7fff52b0a884 0x7fff50dbaa73 0x7fff51550e34 0x7fff50daf885 0x7fff50d7ea72 0x101db0432 0x7fff7b73f015 0x1
2018-11-26 08:37:51.852 SketchUp[4669:373535] BugSplatFramework: exceptionHandler: shouldHandleException name: NSUncaughtSystemExceptionException
mask: 8
2018-11-26 08:37:51.852 SketchUp[4669:373535] BugSplatFramework: getCrashReport: /Users/user/Library/Logs/DiagnosticReports/SketchUp
2018-11-26 08:37:51.857 SketchUp[4669:373535] BugSplatFramework: sendCrashReport: BugsplatReporter is running
Illegal instruction: 4
logout
Saving session…
…copying shared history…
…saving history…truncating history files…
…completed.
[Process completed]
When I open sketchup the program still asks me if I want to reopen last windows or not even though i’ve turned the setting off from my mac settings… I feel like this might be part of the issue
Indeed ironically…
Have you tried turning of the computer, yet, or just restarting?
Yeah I’ve restarted the laptop a few times
In Finder, did you go to ~/Library/Application Support/SketchUp/SketchUp 2018 ?
That is were the (user) pluginfolder resides
use Terminal.app to open a ‘fresh’ SU…
open -F  /Applications/SketchUp\ 2018/SketchUp.app
john
Not sure what plugin i’m meant to delete though, I’ve tried changing the plugin folder name before but that didn’t achieve anything.
Hi John,
When I try that it still produces a bugsplat
Sketchup works in a test user on my mac but won’t work on my main account.
This means something in your main account is installed that is causing the issue. That’s good news. Means you can start disabling other software or additions to begin narrowing it down. If that can’t be done in time for deadline, at the very least you have it running on one account.
You don’t say explicitly…are you submitting the BugSplats to Trimble? The development team takes BugSplats seriously and have the technical insight and source code access to understand what they mean. If you include contact info in the report, they will get back to you, and if you mention this forum topic they may (or may not) also share info here if it appears to be a more widespread issue or bug. Some of us here on the forum are pretty technical, but we are independent volunteers with no access to the SketchUp source code.
That said, in the initial post you attached what appears to be an extract from the system log? The system log often contains progress info, warnings, etc. that have nothing to do with the actual cause of the crash (such as the reports about classes found in more that one library - a harmless error that SketchUp on Mac has had for years and does not cause crashes), and gives those purely hexadecimal stack traces that even an expert can’t decipher. It would be more valuable to attach the actual crash report from
You should be able to find a file there with extension .crash and starting with “SketchUp”. If there is more than one, choose one with a date and time you know corresponds to one of these crashes. This is what BugSplat sends to Trimble.
