Hi all, new here. I am trying to build a house with 20’ x 40 ’ dimensions, and when I input those dimensions, the rectangle shows up as long and narrow. Not nearly what it really looks like. So either I’m doing it wrong or looking at it wrong. Anyone have any ideas?
It’s not clear if you’re referring to use of the Scale tool or the Rectangle tool.
Thus, I’ll treat you to a double feature.
Feel free to ask followup questions.
None of this helps. Years ago I used earlier versions, but now I type in the dimensions separated by a comma and it snaps to a size - just the wrong one. Are there known issues with international settings in the OS? It’s sadly pretty useless if something this basic doesn’t work right off the bat. Any help much appreciated.
Thanks for the quick response. I’m clicking once, releasing, moving the cursor a ways and then simply typing the dimensions. When I hit return the rectangle snaps, but not to the desired size. I don’t see a place to configure presentation of numbers on Sketchup, so I’m assuming it’s the core system. Most other applications and software allow it to be configured locally, but I’m guessing here it takes the system default. I’ll post back if I find a solution!
Anssi has it right, my system requires the use of , and ; as noted. In other software I’ve adjusted in the software, because sometimes I use that standard. Even in Europe it varies by country! I really appreciate the quick responses here in the forum and from Sketchup. I will give myself a little more time before becoming frustrated now that I know a) it’s a great product, and b) there’s such a good support community behind it.
