I used the location feature to help me draw up a site plan for a project. The owner would like to see the plan overlayed on top of the GPS picture. Every time I do it though it is blurry and not clear. Is there any easy solution for this?
The image quality from the Add Location feature is dependent on what the source supplies. Usually Bing is better but not always. One option you might investigate is high res imagery from your local county’s GIS department. Import that imagery into SketchUp instead of using the imagery supplied by Add Location.
no it is not I guess I didn’t describe it correctly.This also the Bing Image. Shouldn’t I be able to use this though without have to use my county’s GIS map?
Your profile doesn’t say you’re using an iPad. It says you have a SketchUp Go subscription. That implies either the web browser version of SketchUp for iPad. SketchUp Go does not include the desktop app.
If Bing’s image resolution isn’t high enough for your needs, you should check with the local GIS agency. You could also look into Placemaker. You can purchase high res imagery from them.
Are you exporting directly from SketchUp? Maybe using LayOut and rendering the viewport as Hybrid will help. Also move the model up above the location imagery so you don’t have Z-fighting.
Select it and use the Move tool to move it in the blue direction. Moving objects in SketchUp is a basic skill. Maybe you should go through the tutorials at learn.sketchup.com
