I’m trying to save the shortcuts I made, but when I restarted SketchUp they didn’t work…
What can I do, please?
Some MAC shortcuts fail if you use a ‘reserved’ key - so don’t try to use cmd+something etc as the system will prevent its use…
Ok, but I was using Shift + !, or Shift + #…
I know, my Mac is really a little old…
I tried both of those, and they should work. You could try closing SketchUp after setting them, then see if they work. If the system had a problem, or SketchUp had a problem, the preferences file may not have been updated.
Well, I think SketchUp had a problem… I followed your tip and closed the software, now when I opened it again the shortcuts were all there… Thank you!
