When I type H for hide it works for a selected item.
When I designate U in shortcuts to do Unhide Selected it does not work.
When you try it out, do you first set View->Hidden Geometry and then select something hidden? The Edit/Unhide/Selected command won’t work unless you follow those steps because you can’t otherwise select something that is hidden!
No, when I had ketchup 8 it worked fine.
Select, press H and selected area goes hidden.
Select U and that hidden item becomes visible again.
That sounds like unhide last, not unhide selected.
Ok. I will try that
Perfect. That works
Also, my SU 2016 doesn’t seem to have the Follow Me tool the 2008 version had
Found it
Figured this one out also
By way of followup on this, SketchUp’s unhide has three variations, each with its own limitations (or, if you prefer, quirks):
Glad that worked. Cheers.
