Dan suggested I start a new topic here with my suggestion for a future version of SU . . .
New SU user here, but old time hand at using CAD. One of the handiest things I did using that other CAD program was to map a couple dozen shortcuts to keys that were under my left hand while sitting on the home row of QWERTY keyboard. I used all the single key shortcuts that I could stroke easily without moving my hand. I then used double key shortcuts to commands. I would also use two-key shortcuts to commands. Using this strategy allowed me to keep one hand on mouse and one hand on keyboard and move very, very quickly thru workflow. I wasn’t constantly moving one hand or the other to a ‘modifier’ key such as ‘control’ or ‘alt’ or ‘window/cmd’ keys. Leaving my hands ‘in place’ was much more efficient for entering shortcuts. True, it took some practice and learning, but once I had the ‘muscle memory’ down, it was quick!
For instance, I would like to make the following ‘shortcuts’:
Single key A = 2 point Arc
Double key AA = 3 point Arc
Single key G = Make Group
Double key GG = Make Component
Sequence FD = Flip Along Red Axis
Sequence DF = Flip Along Green Axis
All the above are easily reached while left hand is on home row of keyboard. Another example, ‘O’ is shortcut for Orbit, but wouldn’t it be great if I could assign it to ‘FF’? At present I can’t do that. Seems SU limits ‘shortcuts’ to a single key, or one of three ‘modifier’ keys along with a key to map that shortcut to a command.
Just a thought and suggestion.
