My preferences for folders seems to work fine for specific items like Components or Materials but how do I set the default folder to open for PROJECTS? It keeps defaulting to my generic “My Documents” folder and I have a specific 3D folder for my work.
The Preferences dialog has a Files section with a Models item.
Set this to your desired folder path, it must be set to My-Documents at the moment ?
I know this is an old thread, but as it’s still open, and as I’m having the identical problem, here we go.
I start SketchUp. I want to open a file that is not displayed in “Recent Files.” So, I click on the handy “Open File” button right there in the middle of the Welcome to SketchUp dialog. A drop down appears (Yeh, yeh, I know…we ALL know this) that says My Device and Trimble Connect. I want a file on the computer I’m using (and sometimes one on my LAN), so I click on My Device. And . . . wham! I’m directed to “This PC > Documents.”
Well, I NEVER use THAT folder for ANYTHING, I use several folders all for different projects under a master folder I call—ready for this?—“Models.” That folder lives under the root on my “D” drive. So to open a file in one of the sub folders there, I have to navigate away from “This PC > Documents” to my “D” drive and to the sub folder and to the file I want.
I guess I could just do all that navigating first, and forget the cute little blue maze icon for SketchUp on my task bar, but seriously? Why can’t I get SketchUp realize that I want the “Open File > My Device” button to take me to my “Models” folder? There is no option in the suggestion by @TIG to do that.
Any help on this?
Open Preferences > Files > Models
you’ll see your current setting - e.g. “C:\Users\-NAME-\Documents\”
Click the edit button to its right and choose a new default - e.g. “D:\Models\” - and OK
Click OK to save and close the Preferences dialog.
Next time you open SketchUp those Preferences should be recalled, and menu File > Open should start there…
IF you Preferences changes are not being remembered, then this suggests an issue the way that SketchUp was installed that has affected permissions - you can resolve this without uninstalling+reinstalling or messing with any customizations like extensions etc.
Close SketchUp.
Fine the SketchUp installer’s exe file - usually in your Downloads folder [or download afresh installer].
Select that exe file’s icon, right-click > context-menu > ‘Run as administrator’…
When a dialog opens select ‘Repair’.
When it completes restart SketchUp and test if changes to Preferences are being retained and recalled across sessions…
Double-Clicking or choosing Run from the context-menu if not the same as ‘Run as administrator’ - even if your user-account has admin powers.
Otherwise, all sorts of unpredictable issues can arise - usually to do with saving settings etc…
TIG:
Wow, thanks for such a speedy response!
So this is what I get when I do the steps you first outline. Steps I’ve tried myriad ways, but always results in the following:
So I ran “Repair,” using the latest install for my version (SketchUp 2025) and “Run as Administrator.”
Then I started up SketchUp, using the shortcut to the .exe file, and got this:
Just as expected. But when I click on My Device, I get this, same as before:
But what I want to see is this:
So I went to check the Preferences and guess what? The files section is just as in the first image. D:\Models. But the Open > My Device still sends me to Documents.
I’m at a loss.
Probably stupid, too.
Still, I’d like to fix it., if possible.
Thanks again, TIG.
I have also noticed the same behavior with the file location as you have shown.
Changing to another drive in Preferences works for me.
And it’s remembered across sessions, so that hints at changes not getting saved or read ?
After changing the Model path to the D: drive if you close SketchUp and reopen it does the change still appear in Preferences or does it revert to ‘Documents’ ?
The path where these preferences are saved on a PC is this:
C:\Users\Thom\AppData\Local\SketchUp\SketchUp 2026\SketchUp\PrivatePreferences.json
It’s editable with Notepad++
Look for the lines in
"File Locations": {
"Classifications": "C:\Users\TIG\AppData\Roaming\SketchUp\SketchUp 2026\SketchUp\Classifications\",
"ComponentBrowser": "C:\ProgramData\SketchUp\SketchUp 2026\SketchUp\Components\",
"ComponentBrowser1": "C:\ProgramData\SketchUp\SketchUp 2026\SketchUp\Components\",
"ComponentBrowser2": "C:\ProgramData\SketchUp\SketchUp 2026\SketchUp\Components\",
"Components": "C:\Users\TIG\AppData\Roaming\SketchUp\SketchUp 2026\SketchUp\Components\",
"Environments": "C:\Users\TIG\AppData\Roaming\SketchUp\SketchUp 2026\SketchUp\Environments\",
"EnvironmentsBrowser": "C:\ProgramData\SketchUp\SketchUp 2026\SketchUp\Environments\",
"Images": "C:\Users\TIG\Desktop\",
"ImportExport": "C:\Users\TIG\Documents\",
"Materials": "C:\Users\TIG\AppData\Roaming\SketchUp\SketchUp 2026\SketchUp\Materials\",
"MaterialsBrowser": "C:\ProgramData\SketchUp\SketchUp 2026\SketchUp\Materials\Brick\",
"MaterialsBrowser2": "C:\ProgramData\SketchUp\SketchUp 2026\SketchUp\Materials\",
"Models": "J:\",
"Styles": "C:\Users\TIG\AppData\Roaming\SketchUp\SketchUp 2026\SketchUp\Styles\",
"StylesBrowser": "C:\ProgramData\SketchUp\SketchUp 2026\SketchUp\Styles\",
"StylesBrowser2": "C:\ProgramData\SketchUp\SketchUp 2026\SketchUp\Styles\",
"Templates": "C:\Users\TIG\AppData\Roaming\SketchUp\SketchUp 2026\SketchUp\Templates\",
"Textures": "C:\Users\TIG\Documents\"
Of course these are all my ‘TIG’ entries…
And a lot of those are NOT in the Preferences but ‘Models’ is - it should be whatever you set it to in Preferences after you close SketchUp ??
If you don’t see the changes saved then running the Repair on the Installer’s exe file as explained earlier might fix its permissions. Also if you find the .json file you can check its Properties > Security setting are FULL ??
It reverts to Documents.
Two minor differences: My user folder is in D:\ and I’m using (on this computer) SketchUp 2025, but I have no such file. The closest .json file is SharedPreferences and that has none of the rest of what you show.
I have, as I said earlier, run Repair. On June 24, actually. And sorry, but no file called PrivatePreferences.json
Maybe I just live with the minor inconvenience. Everything else about SketchUp seems to work just fine.
Thanks anyway.
v2025 is much the same as v2026, so there should still be some saved stuff in your AppData tree. It must save preferences etc somewhere ?
Where have you installed SketchUp itself - C: or D: ?
Why is your user-account based in D: ? C: is the default [sensible] location ??
Is your AppData tree thus ?
D:\Users\Thom\AppData\Local\SketchUp\SketchUp 2025\SketchUp
have you found nothing in
C:\Users\Thom\AppData\Local\SketchUp\SketchUp 2025\SketchUp
e.g. PrivatePreferences.json
Is D: a network drive or a plugin USB drive ?
SketchUp is installed on C:\Program Files\SketchUp\SketchUp 2025
For several reasons: Almost without exception, config files of which D:\User\Thom is one, are installed on D: because that keeps C: from becoming fragmented. It’s secure, it works, it’s faster, and it’s easy to point software to it (with the exception, apparently, of SketchUp).
Yes. Exactly.
Correct. Nowhere on C: in this computer s there a file naked PrivatePreferences.json or, for that matter, anything called PrivatePreferences anything.
Edit
I did find, however the PrivatePreferences.json in D:\Users\Thom\AppData\Local\SketchUp\SketchUp 2025\Sketchup. I had been looking in :\AppData\Roaming . My error. I misread your directions.
However, in the “File Locations” section, it reads precisely as I want it to. See the emboldened lines in that section shown below.
“File Locations”: {
“Classifications”: “D:\Users\Thom\AppData\Roaming\SketchUp\SketchUp 2025\SketchUp\Classifications\”,
“ComponentBrowser”: “C:\ProgramData\SketchUp\SketchUp 2025\SketchUp\Components\”,
“ComponentBrowser1”: “D:\Models\ECMRRC\BeaverFalls\RattyOldHouse\”,
“ComponentBrowser2”: “D:\Models\ECMRRC\Parts\Pipes, Fittings\”,
“Components”: “D:\Models\”,
“Environments”: “D:\Users\Thom\AppData\Roaming\SketchUp\SketchUp 2025\SketchUp\Environments\”,
“EnvironmentsBrowser”: “C:\ProgramData\SketchUp\SketchUp 2025\SketchUp\Environments\”,
“Images”: “D:\Users\Thom\Documents\”,
“ImportExport”: “D:\Models\ECMRRC\Models to Print\STL_FIles\”,
“Materials”: “D:\Users\Thom\AppData\Roaming\SketchUp\SketchUp 2025\SketchUp\Materials\”,
“MaterialsBrowser”: “C:\ProgramData\SketchUp\SketchUp 2025\SketchUp\Materials\Metal\”,
“MaterialsBrowser2”: “C:\ProgramData\SketchUp\SketchUp 2025\SketchUp\Materials\”,
“Models”: “D:\Models\”,
“Styles”: “D:\Users\Thom\AppData\Roaming\SketchUp\SketchUp 2025\SketchUp\Styles\”,
“StylesBrowser”: “D:\Users\Thom\AppData\Roaming\SketchUp\SketchUp 2025\SketchUp\Styles\”,
“StylesBrowser2”: “C:\ProgramData\SketchUp\SketchUp 2025\SketchUp\Styles\”,
“Templates”: “D:\Users\Thom\AppData\Roaming\SketchUp\SketchUp 2025\SketchUp\Templates\”,
“Textures”: “D:\Users\Thom\Documents\”
D:\ is a partition of the physical SSD hard drive, 512GB, in this computer. Which is a Dell DMP-3560. It is the computer that I do most of my 3D modeling on. I have another desktop computer, configured similarly, that I use to do architectural work. In the desktop, D: is a separate physical SSD drive. (It also contains partitions E: and F:, which are used primarily to store virtual images of the data drive.
The only thing I use my local network for is to access data files. I do no computing across my network.
When you open Preferences > Files does it say “D:\Models” in the right section ?
SketchUp should read this and use it as the default starting point for model save/open ?
Perhaps @colin can chip in here…
When I open Preferences>FIles, yes. It says D:\Models, as it has since I changed it there in hopes the opening screen would take me there in one keystroke instead of, I dunno, 6 or seven?
In my earlier post I presented screen shots of the welcome screen sequence that show just what it does now, despite my opening the .json file that in my more recent post showing the Files locations section of that file also points to D:\Models.
SketchUp ignores it.
put a permanent shortcut (to your desired folder) into the opening location
