Separate the erase and hide commands
Is it too much to ask to separate the “erase” and “hide” commands on the drop down menu? Just put the “lock” command between them. Maybe it could be:
Entity Info
Hide
Lock
Erase
Please don’t respond with the short cut keys and components versus groups, I don’t care. Just fix the menu and this problem will go away forever. Thank you.
I don’t see any problem. If I want to hide I will choose menu “Hide” if I wand delete I choose “Erase”.
Similar as if I want to go I push accelerator pedal, If I want to stop then the brake pedal.
BTW. There is no “lock” menu if you mouse is over e.g. edge…
When you right click a component or group the drop down menu is:
Entity Info
Erase
Hide
Lock
etc.
I would be very happy if the programmers at Sketchup could just rearrange this menu and separate the “Erase” and “Hide”.
