Erase and Hide from the right click menu
Would moving the Erase and Hide further away from each other (in the menu system) be a problem? They both make stuff dissapear. But one is more permanent than the other. I think if I was working at speed, I could miss the hide from the erase.
I hope you understand.
Process:
  1. Right click, Hide… oops I slipped the mouse up to erase (didn’t notice)
  2. Hey it Hid
  3. work… work … work… save, save ,save
  4. Unhide…
  5. where did it go?
  6. Back to a backup… :frowning:
This would be a good idea.
+1
That happened to me last night, when unhide last hided group nada. I had even realize that they are next to each other
Another good reason for using components instead of groups. If you’d erased a component, you could drag in a new instance of it from the In Model components collection. :wink:
Get it!
Tks
If you assign a shortcut, e.g. Ctrl+H, for hide you will be able to model quite a bit faster and not risk deleting.
