Hi Everyone,
I have finished my layout in sketchup and need to send to Layout. I had to create a title block in layout. It won’t let me add the plan to layout with the title block I have already created. I’m completely new to this software. It’s an assignment for school. Am I doing something wrong? Is there a way to add it to the titleblock in layout that I have already created? Thanks so much!
Do you have two different files? Have you tried to copy your titleblock from one of them to another?
To expedite resolution post a copy of your sketchup file. I probably won’t be able to help you but those that can will need to see your SU file.
To help achieve your goals, some time spent at the SketchUp Campus and at the SketchUp - YouTube channel will be very worthwhile. Both sites are from the SketchUp team. On the YouTube channel, pay attention to the Square One Series and Level UP series. They cover the basics for each tool.
If you already have the LayOut document with the titleblock created, g to File>Insert and insert the SketchUp model.
If you would save your LayOut file with the titleblock using File>Save as template, you could use Send to LayOut in SketchUp, select the template you created, and start your document.
Thank you so much!! This worked ![]()
