I tried installing Sefaira 2020 and followed the instructions from sefaira support ([https://support.sefaira.com/hc/en-us/articles/115001624152-Section-2-Accessing-Sefaira-and-Downloading-the-Plugins-]), I run through all the steps right up to where I select Extensions>Sefaira Plugin>Show Sefaira Plugin but the installer doesn’t open and all I get is this error message:
Assuming this is a backend issue - any advice?
Did you restart the computer, by any chance? Sometimes, this helps.
Do you have a VPN installed or firewall blocker?
Maybe it is a port that is not open.
Check:
500 indicates that a connection to the server is made, but that there was a crash in the server’s running code.
Thanks for replying both. Mike, I ran through all your suggestions but nothing seems to have worked. The urls that the ports need access to are also returning error messages - maps.sefaira.com in particular:
So I guess I have to wait for Sefaira to fix it their end. I have been onto them too. Thanks again for the suggestions!
