Section Line does not match on SketchUp and Layout
hi. this is the problem for me for several years, and for several version.
(currently im using 2024 Version)
on SketchUp. the section line is all showed fine when perspective or Parallel. but fade when change to standard view.
Parallel View
Standard View
Then it turns out that in LayOut, the file reference can’t show all section lines, especially when there are two geometries with the same width or length, like this
is there is a way to fix this.?
Can you share your Layout file?
Please update your profile if you are using SketchUp 2024
The Section Cut line is controlled by the style. Is the LO view using the same style you are working with in SKP?
Also, in Raster mode you can adjust the quality of the viewport while editing. It often looks thick and rough before exporting. What does it look like if you export it to PDF?
Have you adjusted the settings in Document Setup>Rendering?
Please post the file.
when export to PDF
DED ROYAL SUDUT 26 8 2024.pdf (206.2 KB)
this is the file if u want to look.
https://drive.google.com/drive/folders/19nMYOYR5hR5z6RqSxRyI-YCqFSsbdOyI?usp=sharing
Play with line scale…
Hi thanks for the respond. I’ve tried.
the line weight just adds more visible line to the one that are already visible. at least for me. the problem is this one
this is how the sketchup actually need to showme in layout.
the rectangle Line of Beam should be visible.
but instead showed all these line. the Layout just show this
Screenshot 2024-09-03 161021 1
The red line needs to be showed.
or maybe the overlapping object of Wall and Beam was the problem? I can trim the wall. but I need them to be overlapping coz the structural beam needs to be hide in various scene.
If you deselect fill section cut in the style. Can you see all section lines in layout? If not there is something overlapping.
I’m not now at the computer to test it.
In effect they are overlapping, the section cut is only showing one fill
