I have scenes set in Sketchup that were showing fine in Layout, and now out of no where the section cuts seem to not be showing so all I see is the outside of the wall. Anyone know why this could be happening? Thanks!
Scenes not set up correctly? Style not updated? Different style selected for the viewport? Share the LayOut file so we can see what you have. Send it in PM if you can’t make it public.
It indicates that style has section cuts and fill enabled. Is there an active section plane in the scene you are using for the viewport in LayOut? Are you using this style for the viewport in LayOut or is it possible you’ve selected a different style?
In LayOut; Go to tray > SketchUp Model panel > Style > Reset.
If not working try Viewport > Reset.
This helped me out more than once.
Perhaps now for you ![]()
