Hi All,
I have a model that has a bunch of section cuts and all were saved to scenes, floor plan, sections etc. everything has worked well for some time on this model.
today I changed the ground level group in my model and now every saved seen that had an active section cut applied to its relative scene has turned off.
Can anyone shed some light as to why this would happen?
I have since fixed the model by reactivating the scenes and resaving them so unfortunately don’t have a copy of the model to share. I only though to ask here afterwards to try avoid it happening again.
Scene visibility state is a style property. If you edited the style used for those scenes to turn off section cuts and updated the style, perhaps when creating a new scene or updating a scene, any other scene using that style would also have section cuts turned off.
If you share the .skp file it would be easier to accurately diagnose the issue.
Thanks Dave,
I didn’t edit any styles or scenes, I only swapped out a group with updated survey information. every scene and style was to remain unchanged.
I will have a look into my incremental backups to try and find .SKP version before I fixed it. I should have asked here before manually fixing it. it was post fixing it I thought someone may have had a similar issue and knew what it was.
