Section Cut lines selectable?
My question is:
Is there a plug-in or some other way to turn a section cut line into an actual, selectable line? I would like to take a topography line from a section cut and copy it (use it) without having to trace over it.
I’m sure I’m probably just missing something very simple to do this, no?
Please advise.
Thanks,
Joel
Select the Section-Plane.
Use the context-menu > Create Group from Slice…
Or to add faces, consider using my own SectionCutFace tool with settings to keep/show edges… or look at the even more comprehensive Skalp…
Edit the resultant group to access the new edges…
(withdrawn) TIG explained it better.
post withdrawn …20
