Section cut fill problem when using Vali Architects door/window extention
I have been using this extention for years, little troubles. But lately, when I insert a Vali door in walls, section fill will not work on that wall. Sometimes (but not always) it will help to make the back side “frameless”.
I tried everything I can think of - anybody know the issue?
test.skp (418.8 KB)
sec-05
It is a common issue with the Section Fill style feature. It only works when the closed loop of section cut edges belong to the same context, so, for instance, opening-cutting components disrupt the loop and prevent the fill from forming.
Ahhh… thanks so much! :grinning:
