I’m using SU Pro 2019, downloaded the latest update this morning.
I have a terrible time zooming in / out with my mouse scroll wheel. I’m currently using a Logitech vertical mouse, but this issue has been the same no matter the mouse I use, or year / version of SU Pro. The scroll wheel zooming is very erratic. If I scroll too fast in or out, I can be way too close in or the page zooms out so that the model linked image is the size of a postage stamp. I’m trying to dimension a large home, and at 1/4" / FT, I need to zoom in to pick a point, then zoom out, then back in on the next point to get the dimension. I find I have to zoom in/out in/out to finally get it to the view I need, as the view just jumps in and out with the scroll wheel. I try to pan midway through a dimension operation (instead of zoom), but the hand / pan tool will not release back to the dimension tool, even though the dimension tool is still showing as selected in the tool bar; the dimension tool simply does not return unless I select it from the toolbar, at which point I’m starting all over.
This is not only very time consuming, but frustrating as well. Dimensioning takes twice as long as it should.
I’m on an iMac. Has anyone found a way to make this operate in an acceptable manner?
The whole Sketchup / Layout use and flow is so maddening. There isn’t anything I can’t do in SU/LO, I just can’t do it easily as it seems I have to constantly fight the application short comings. And if it weren’t for the plug in developers, SU would have passed on a long time ago. I’ve never used any other 3D software, so maybe they’re all as clunky.
