I’m experiencing a strange performance issue with SketchUp + Scan Essentials when using an NVIDIA GPU
When Scan Essentials is enabled and the SketchUp window is active in the foreground, SketchUp becomes noticeably less responsive;
Windows Task Manager shows the NVIDIA GPU 3D engine jumping very high, often close to 100%, even if I am not moving the camera or interacting with the pointcloud.
At the same time:
GPU Copy usage remains very low
the GPU load drops almost to zero as soon as SketchUp goes into the background
if I disable the pointcloud visualization, performance goes back to normal.
Point clouds are often large files, several gigabytes. How responsive is your computer if you open the cloud with some other software, like AutoDesk’s ReCap?
The same point cloud runs smoothly on other software.
The problem appears to be specific to Scan Essential Viewport and hardware setups with multiple GPUs. Even switching the dedicated GPU in SU Graphic preferences doesn’t fix or alter the behavior, SE always uses the NVIDIA GPU, even when it’s not selected as the primary GPU.
Yesterday I supposed it was an NVIDIA bug or settings to adjust, now it’s more like a SE Viewport bug.
So, is your Nvidia driver up to date?
Your profile is out of sync with what you write in your posts, telling us that you are using an older Mac with an AMD graphics card.
The driver is the latest, the machine is a MacBook Pro 2018 i7 with AMD iGPU and NVIDIA eGPU. I’m using the mac as a native Windows machine with Bootcamp.
To me the issue seems to be in SE graphic pipeline, not in SU.
The whole setup is IMO rather exotic…
Have you checked in the Nvidia control panel 3D application settings that SketchUp is set to use the Nvidia GPU? The default Automatic selection might be problematic.
Multiple GPUs are pretty normal, particularly in laptops.
It’s when you start bolting on external GPUs that things get messy. Driver, API and OS support isn’t nearly as straightforward, and in this case you’re also talking about a 12-year-old Mac with a relatively slow interface between the system and GPU and no modern driver support from Apple.
I was having the same issue with my eGPU. I discovered that while my EGPU can run SketchUp that even USB4 doesn’t have the bandwidth for point cloud files. I’ve always wondered if Oculink could do the job but don’t have the tools. the only way I could force scan essentials to use the iGPU and not have issues was in the Nvidia Control panel, change the program settings for SketchUp for “Open GL Rendering GPU” to use the iGPU or any internal GPU.
I would recommend using the NVIDIA control panel to assign the GPU you want SketchUp to use.
I only have an RTX 3090 with an Intel i7 on my windows PC and Scan Essentials runs fine so long as the point cloud is less than 500M points. Once I get above that it gets clunky when I orbit, but even then if I create a clipping box to reduce the visible points it goes back to full performance.
Windows itself also has a setting per app in “graphics settings” , I don’t know how that and the vendor APIs interact, so it’s probably worth doubling up
SketchUp already lists the NVIDIA eGPU in the Graphic Engine.
Scan Essentials uses its own rendering libraries, independently from SketchUp’s graphics engine. So even though SketchUp is running on the right GPU, the point-cloud renderer may be using a separate graphics path, and, as far as I know, there’s no way to force it to use one GPU rather than another…
I will say as I leave this one to the real pros: I do have some workflows in CloudCompare that I perform well before I bring a point cloud into SketchUp via Scan Essentials. I’ll remove outliers, classify, and if there are portions of the point cloud I can reduce via subsampling (usually the ground), I will. The only areas that I actually need/want points to be very dense are the assets that I’m going to texturize with the point cloud. Other than that I just need enough to model off of.
