Please help, I need the point cloud to work so I can print the project and send it off to the client.
Issue: Scan Essentials says it is loading the point cloud file, but does not show the point cloud in SU or LO.
Monday, I updated to SU and LO, and Scan Essentials 2025.1013 (SE). But when I tried to export a PDF from LO, it crashed every time. I switched to the SU’s classic driver, and the results had the point cloud rendering over the model, even though it was behind the model.
What I have done:
So, I looked at the Windows 11 event logs and noticed the “NVIDIA OpenGL” driver could not be found (see Loggeded:2025-10-21 10:28:20 PM and Logged: 2025-10-21 10:28:36 PM) .
- Update the driver through the Nvidia App, and it did not fix the issue.
- Tried a reboot with no improvement.
- Did a clean/complete driver uninstall using DDU and downloaded and installed the Nvidia Driver and rebooted the computer.
- Opened LO and exported a PDF and got a .NetRuntime Error (see Logged: 2025-10-21 11:04:01 PM).
- Using the Window’s uninstaller, I uninstalled SU and LO
- Redownloaded and reinstalled SU Studio, with Scan Essentials.
- Reboot the computer
- Open LO and exported pdf - printed fine, but no point cloud showing.
- Open SU, did not show the point cloud.
- Tried reloading the file from the e57 and then tried another rwp file that was working before and still it did not show.
- Tried turning on and off the point cloud section, clipping, and inspection options to see if they got turned on somehow.
- tried zooming all to see if the point cloud got shifted. - no dice.
- Tried reinstalling Scan Essentials after removing the su_pcp.rb file and folder form the Plugins folder.
Hopefully someone can help me to get SE working again.
Thank you for any suggestions you can offer.
Window’s 11 Log reports:
Application: LayOut.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.AccessViolationException
at .LOQtEntryPoint(HINSTANCE__, HINSTANCE__, Char*, Int32)
at .wWinMain(HINSTANCE__, HINSTANCE__, Char*, Int32)
at .wWinMainCRTStartup()
Faulting application name: LayOut.exe, version: 25.0.0.0, time stamp: 0x68363888
Faulting module name: nvoglv64.dll, version: 32.0.15.8157, time stamp: 0x68e83c0d
Exception code: 0xc0000409
Fault offset: 0x000000000108f0cd
Faulting process id: 0x6700
Faulting application start time: 0x1DC42FB403CC0F9
Faulting application path: C:\Program Files\SketchUp\SketchUp 2025\LayOut\LayOut.exe
Faulting module path: C:\WINDOWS\System32\DriverStore\FileRepository\nvltsi.inf_amd64_7d04bd4cae6a0fde\nvoglv64.dll
Report Id: a588740b-63a8-4fcc-bfbf-b8ac857e030a
Faulting package full name:
Faulting package-relative application ID:
The description for Event ID 1 from source NVIDIA OpenGL Driver cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
An application has requested more GPU memory than is
available in the system.
The application will now be closed.
