Hello, When I use a component from the 3D Warehouse none of the color or texture shows. All I can see is a black outline. Only when I zoom in really close can I see the color and detail of the object. How do I scale the object so that it can be seen in my model. I’ve tried the scale tool, but no luck. Thanks so much!
Can you share an example SKP file that shows the problem?
you can change a stretched or sunken texture on a scaled component by right click menu on the component and choosing “scale definition”
you can change a texture scale in the edit tab of the material pallet
