Is there a way to scale proportionaly an imported image in Layout?
Thank you.
Chris
Thank you.
Chris
Hold shift while you drag the corner will resize the jpg while keeping the height to width ratio the same, if thatâs what you mean.
Thank you Box!!!
Hard to beleave, after so many years working with SU, I didnât think about it. ![]()
Keep an eye on the task bar at the bottom in both Sketchup and Layout, it tells you what modifier keys are available for the tool currently in use.
Yes, thank you ![]()
But what if you are looking for a very specific scale percentge? The scale tool in2026 is not giving you exact control. If the answer is trial and error, thatâs fine, but I;think that is still a workaround.
Thank you!!!
