I need help applying different radius values to multiple edges in SketchUp. Is it possible to apply different rounding values to different edges in a single model ‘in one go’ using Round Corner or Bevel Tool plugins, or are there any alternative methods?
Has anyone successfully implemented this kind of workflow? Thanks for any plugin suggestions or alternative solutions.
Neither bevel or Round Corner can do what you want in just one step, you can bevel different corners but the distance is going to be the same. Also it will probably need some manual fixing the corner where you have different bevel distances.
i found solution with FredoCorner plugin. There is offset settings while rounding edges selected. Plugin allowing us to change offset on different edges like exactly what i want.
If someone looking for the same solutions; check this video;
