Here I got another problem. I am trying to make nice and smooth path as on pictures below.
But as you can see this way does not make faces ‘right way’ as artifact can be seen - however I don’t like it.
Is what you are trying to draw a helical ramp? If so, you might find it easier to use one of several plugins that do the hard work for you.
Try (from the SketchUcation plugin store) SU Parametric Shapes, or google for Spirix plugin (not sure where to get that). There may be others I don’t know that do something similar.
It is indeed possible manually, if you don’t have too many segments in your curves, and you can smooth the results to soften the edges.
But as you found it is tricky tricky to get right.
For a manual method, you could start with two concentric cylinders or half cylinders, make them into a component, then draw a series of points up the sides on the segment lines with the tape measure, incrementing the height by a suitable distance for each segment. Then joint the points with lines.
Because I am new to SketchUp and I want to do it using clear software + I want to know this app deeper. It should be possible, as this is basic thing to make - I think.
Finally I stay with this unless someone got another automated good solution.
Cause, when you want to make it more smooth (add more segments) it take much more time to do it manually.
These are good reasons and I salute you! Too many newbies want to jump straight to advanced stuff before they understand how SketchUp works.
Just be advised that though there is nothing a plugin can do that you can’t do using the built-in tools, sometimes the manual way is extremely complicated, subtle, tedious, or time-comsuming!
