It looks like it is not possible to rotate a dynamic component over multiple axes.
When I add the rotation properties to my dynamic component and change e.g. RotX it behaves as expected.
However, as soon as I try to rotate over the Y or Z (RotY or RotZ), the initial RotX will reset to 0.
I’m not at my computer so I can’t check but I remember there may be some inconsistent behavior depending on which axis the rotation is using. Rotating around an axis may reset the other rotations.
Or just moving a component resets a rotation even though that rotation has not been referenced in the component.
Thanks for your proposal. This works in case you do not want the user to edit this attribute in the option window.
If you let this attribute open for user input, I have got still the same problem.
Allthough it is correct that you can work this way. It causes that the normal rotation tool does not reflect its angle anymore in the attributes of the component.
I hope this can be resolved in a later version or another workaround is possible.
As PCmoor mentioned using custom attributes allows for the current axis value to be changed and updated. I made a component that uses his examples you may find helpful. Activate the interact tool and click on the control buttons to test. tilt_rotate.skp (83.5 KB)
