Rotated View with Parallel Projection (front back left right)?
Is it possible to create a view with parallel projection settings that is not on the primary axis with the front, back, left and right camera options? If not how would I set this manually? Thank you!
Right click on a face and select Align View, then make that a scene. Repeat for other views.
Thank you!!!
You can do that by changing the axis but I recommend you to create a plane perpendicular to the view you want to achieve, right click on it and on the contextual menu select align view. Of course the easiest way is using a plugin like fredo portrait.
