Revit Importer - Sketchup Studio
I have been importing revit files into sketchup which works well on the smaller files but keeps failing on larger models.
I have tried this on 1.5G to 2.5G architectural apartment tower models and they either fail half way through or the majority of the time complete, after a long time and then also fail.
Is there a limit to the revit files that should be imported or is there something else i should be doing.
One option i have is to buy Revit LT and reduce the file size but didn’t want to have to do this if there was a free or easier path forward.
All advice is welcome
Maybe @tomj has an idea of what could be happening.
I don’t think there is such a limit, but more a case of the available RAM on the system.
Autodesk said it improved workability for model up to 1Gb with the recent version, but in general it is better to keep the Revit files below that (800 Mb)
That’s without external files, of course.
If you do not have access to Revit, one can create a project in Trimble Connect for Desktop and add the Revit file.
Then create a view and select only what you need in SketchUp and export that as a TrimBIM file.
Though the organization is slightly different, one can come up with a workable file in SketchUp.
Check this thread about another Autodesk format:
Is it possible to share any of the models that you have tried to import that have failed? I have not had issues with large files failing to import but I have never imported a model larger than about 700Mb. I would like to see if I can get them to import or if it fails for me as well. I am unaware of a model size limit but I think @MikeWayzovski is likely right about it being more of a case of available RAM.
The large models you are getting, were they created by merging multiple linked Revit files? Often architects will have a “main building” model with the units or interiors as linked in models as well as structural, mechanical and other models linked in. If this is the case it might be worth asking if you can get the models and linked models separately instead of all merged into one. The Revit Importer includes Revit link support and I have had success with importing multiple linked Revit models, that if merged would be a 2-3Gb Revit Model, into a single SketchUp model.
I have this problem too. I only just upgraded to SketchUp Studio to be able to use the Revit Importer and with large files I get an error message saying “Conversion failed”. So annoying, the importer as the only reason I upgraded to the Studio plan. :frowning: Has anyone found a solution? My file is 300Mb so not THAT big.
Hey SaintCecilia,
Could you share your file and I will investigate.
JH
Thanks @Jacques! Much appreciated.You can find the file here:
error message when importing in RVT 2024:
I set the {3D} view current and then saved the file, imported it in SketchUp 2023:
