Is it normal that the extension Revit Importer for SketchUp get updates almost every week for the last 6 months or so?
It’s a bit annoying for me because I don’t use it and it’s disable in my Extension Manager.
I’m on Win11 v.25H2
SketchUp v.25.0.660 64-bits
Revit Importer for SketchUp v.1.2026.1.8
Cheers!
There have been a few updates recently as we improve things.
If you don’t use it, don’t install it when you install SketchUp by unticking the box, then it won’t try and update.
Dan
I tried uninstall it but it always come back. I guest like you said, I need to reinstall SU and not checking the box. It will give me the occasion to update to v.26. Cheers.
Yes, as pointed out in Sketchup crashes after uninstalling revit importer plugin - #2 by ateliernab the Revit Importer uninstaller doesn’t work properly, so not installing is the solution. This is an annoying bug, been on our list for ages, but it would require quite some rework to fix due to the way Revit Importer was originally created, so keeps getting bumped down by higher priority fixes.
Dan
