Hi all,
My first post to the forum. I managed to get a model into the wire frame mode, but that was a week ago. Now I can’t figure out how to make it revert to the standard mode.
Thanks in advance,
Millwright74
Hi all,
Thanks in advance,
Millwright74
Hi Millright74, hi folks.
Alternatively, you can also use View menu → Face style to make the Face Style Palette visible. Then, position it where it is convenient for you, for example, on the left side or the top of the Model window.
With this palette visible, you are only one click away from many rendering possibilities.
Just ideas.
Jean
The sequence that jean-lemire cited does not exist.
He knows how to do it, but he knows it so well that he cannot give a beginner an accurate sequence of tasks…
The ACTUAL methods for displaying and using this MENU Palette is this:
Xray
Back Edges
Wireframe
Hidden Line
Shaded
Shaded with Textures
Monochrome
You are welcome !
I should have checked your profile to see that you are using the Windows version of SketchUp. I use the Mac OS version.
However, the idea is the same, showing the Face Style tool palette. On Mac it can be done using the customization of the Toolbar. Do a right click on it then slide the Face Style tool palette on the Tool bar at the top of the Drawing window. I know it is different for SU on Window. It is like you describe it.
In my post I should have stated that the procedure gives you access to a list of the available Face Styles from which you can choose the required one. It don’t show the Tool palette.
