Results of Validity Check - Can't save work???
Results of Validity Check.
*** Problems were found that could not be fixed! ***
The entity at address 799d62b0 has an invalid id (0) destroyed (0)
Hello @thevoyager and welcome to the SketchUp Community.
Your post reveals insufficient information to describe what you are encountering. It may be helpful to include a screenshot showing what appears and a description of what you were doing when the issue was first discovered.
You should also correct the inaccuracies (I don’t believe you are using a “version 2” of Make…[SketchUp 2 is over 10 years old], state which version of ios you have, and “dunno” is not a recognizable graphics card name) and complete your user profile. This will help other users to better assist you.
Because you are new to this Forum, several useful links are provided FYI. I hope you find them helpful.
I am sure you will find your participation here to be enlightening, informative, and enjoyable. FYI, several links are provided HERE and HERE to direct you to some useful info relative to this site. (Click on the bold text.)
As a new SketchUp User, I want to help you quickly become familiar with some of the best ways to make use of SketchUp and to best communicate your concerns here on this Forum. I have attached several informative videos below for your review. These may offer some additional guidance as you continue to learn SketchUp. Just click the boldfaced text to be directed to the referenced links.
Getting Started with SketchUp - Part 1
Getting Started with SketchUp - Part 2
Getting Started with SketchUp - Part 3
Getting Started with SketchUp - Part 4
The video links that follow exhibit a feature that is only available with SU Pro (and SU Shop) but not available with SU Make (or Free). These are provided to give a glimpse of the potential of this extraordinary software.
Getting Started with LayOut
Layout Tips
Again welcome, and feel free to ask as many questions and to post as frequently as you wish. I look forward to your becoming an active member of this Community!
I am confident that you will find your experience in this online community to be positive!
What is the actual problem? Does the validity check prevent the model from being saved? Does the check destroy something in the model?
I am trying to save my sketch up project, and this screen comes up, see pic.
Is the file being saved? Can you press OK and just save again?
In most cases, these kind of errors appear with imported 3D warehouse components.
It could be a nested component with the same or something like that.
Do you purge first? Window->Model Info->Statistics->Purge unused
Did your instructions and same thing… Same box pops up…
I have a project on and don’t want to loose it if computer dies… I have used some 3d warehouse models yes… any ideas?
I found this on a diff thread…
“It is not a virus, but a bug that somehow corrupts the model’s geometry database. Some reports suggest it happens when an imported component has the same internal name as the file that contains it.”
Sometimes you can copy and paste the model into a new instance of SketchUp.
Explode the 3D warehouse models(rightclick->choose Explode) keep exploding till ‘explode’ is grey.
While all geometry still is selected, right click and choose make Group/
Component.
If you have multiple instances of one 3D Warehouse component, first, right click the component and start exploding in that contex (eg. While ‘in ‘ the component)
Purge and check validity
sorry… so expode every 3d warehouse model, but they all have to be selected at the same time?? Can you please explain till explode is grey.
Not necesarely, if there is one of each component in the model, do it per component, if there are multiple instances (copies) edit one and start exploding. If ‘Explode’ is greyed out, you are at the level were only faces and edges remain. While still selected, you can group it to prevent ‘stickyness’
Just did all that right click explode, make compnent on all 3d warehouse models and nothign, same…
It’d be a shame ot loose this file…
Interestingly though it does save a file to the destination - It doesn’t actually say it can’t be saved… so it is saving but just lettig me know there are problems?
The validity check runs when saving, but should typically not affect saving.
