Hi all,
I recently just updated to Sketchup Pro 2020 and the newest version of Vray and am running into a strange minor issue. (see image attached)
In a nutshell, the materials in the model display one way, and when rendered, rotate 90 degrees.
I’ve checked in the Vray material editor and there is no rotation on the diffuse image file. This material was created from scratch so there was no rotation anywhere in the material. This has also happened in an entirely different model and materials.
The point is, if the faces are reversed in your model, you can have issues with rendering the materials correctly. So if you have back faces up on the floor, you need to reverse them like mihai.s shows. Look at your model in Monochrome face style, you should see only white front faces.
Dave,
I was able to sort that out. My comment was that this only flips in one direction. Basically just flipping the white and black tiles to black and white in order…which is not the axis that needs to be flipped. It needs to be rotated. Is there maybe a way to assign a different axis to a given material? or assign an axis to the component?
