Hi. I need to rotate a vray plank material but when I do it does not render correctly. I rotate the texture with the sketchup texture rotate window and it shows up correctly in model. However, when I render, the planks show up in the original position. Any help would be much appreciated. Thanks!
Thanks! that was the solution.
Just so you know, many renderers will ignore back sides of faces completely, not just ignore texture positioning. Always edit a model in monochrome mode so that face orientation is obvious. Correct any reversed faces before you apply materials.
