Reflective light showing in V-Ray Render
Hi everyone,
For some reason, when I’m rendering on V-Ray, there’s this white reflection on the top right cabinet that is not showing in the SketchUp scene. How do I remove this?
Can you share your model here? If too large in size use dropbox or google drive. It appears connected to the section cut. But hard to say how to fix without seeing how it’s set up.
Let me know if the link works: https://drive.google.com/file/d/1Ed_Yt2w9A_bcbI4ZftTM0JC48qmttoqe/view?usp=drive_link
It seems to be a bug with the way the section plane material is showing up. I tried moving the cut further into the room, which helped remove most of the large white squares, but still left some smaller ones.
I’d recommend turning off the section cut material. It may mean a few mins of manual work in a post-production app like Photoshop if you want to bring that section fill back in.
Thank you.
