Reduce a model down to a simple massing/mesh
Is there a way to take a sketchup model of a building for example, and create a dumbed down version of it to place in the background of a site. Basically I have models for buildings that are detailed and large in file size and I want to easily create some sort of mesh/skin that can wrap the model creating one simple component that still looks the same. I want the same level of detail but do not need each individual window frame etc. and will only need the exterior nothing on the interior. as it will all just be white.
any suggestions on plugins or extensions. I have tried Mesh Wrapper, I need something like this but one smooth surface and more level of detail. almost as if you were to 3D print the model and just need an outer shell if that makes sense.
If the model is built from solid groups and/or solid components, you can use SketchUp’s right-click->outer shell command to generate the (duh!) outer wrapper with no loss of exterior detail. But it only works with assemblies of solids; it will not accept loose geometry or objects that are not solids.
thanks! Yea, unfortunately it is not a solid so I am not sure this will work! It is the right idea though!
hello, you could have a look at ghostcomp by fredo6. you have many parameters to simplify a component.
ghostcomp has been improved in a licenced version, fredoghost
https://sketchucation.com/forums/viewtopic.php?f=323&t=21469
[Plugin][$] FredoGhost - v1.9a - 04 Jun 21 • sketchUcation • 1
How to Use Fredo Ghost in SketchUp - YouTube
I tried it and it doesn’t work. It actually doubled my file size and when I want to render it is still to slow/crashes.
are the window frames components, do they have a different material applied ?
can you send an example skp file of the buildings you want to simplify ?
It was originally an export from revit so there are many different groups as well as layers in the model. Unfortunately I can not share the model because it is for my job and a breach of privacy. I have been looking into this all day and still have nothing. I did find a tool in Autodesk called Shrinkwrap which is essentially what I want to do to my model but it seems no such thing exists for sketchup.
There is also a plugin from thom thom called “shell” which I thought would work and it does for simple objects but not for a building with so many groups and components. :frowning:
I also looked into if I could somehow make the entire model a solid group (I have no idea how I would) I could potentially use sketchup’s outer shell tool like slbaumgartner suggested.
I suggest you export differently from revit, using filters. You can choose what type of objects you need to export from there.
you say it has many different layers, none of them could be cast away without compromising the general integrity ?
Yes the layers are directly imported from revit too (ie. window frames, glazing, walls, etc) the thing is that they all come in as groups or components and literally all I need is the outer 2D shell. The revit model export is still very big for what I am doing even with interior elements turned off. I don’t even really need wall thicknesses. This guy on this forum seems to be wanting to do exactly what I need but no one could really help him either Create an outer shell from complex model
I am starting to lose hope on it
what is your renderer ?
I’m using enscape
I also faced this problem Right Now …!!
Making a 2D Solid Outer Shell :slight_smile:
Did you find anything ???
@ArshiaCC :
This thread is 2 years old and @samcharlinski doesn’t seem to be a frequent visitor here so I very much doubt that he will answer you…
Hi folks,
This is an old thread, but if somebody comes around for similar issue, I developed a plugin that may help solving it. Please check out BIMShell.
BIMShell_voxelShells_1080p
BIMShell_short_gif_480p_480px
Here is the dedicated thread in the forum with more information. Hope this can be of any help!
I encountered difficulties while installing your extension . I am looking forward to your reply and help.The error is as follows:
You need to give us some more information.
  • Which extension are you talking about?
  • Where did you download the extension from?
  • How are you installing the extension?
  • What graphics card do you really have? This info is important for a lot of questions!
FWIW: This is a users forum, so it is therefore not “our” extension…
Pretty sure they are taking about the post directly above - the BIMShell extension.
:face_with_open_eyes_and_hand_over_mouth:
Sorry, thought is was an opening post…
It means that the tool hasn’t been able to communicate with the server. It generally happens when you use a VPN, or DNS of some sort (or potentially some firewall restriction, but this is less likely).
If you use any of those, try to deactivate them temporarily and let us know if that works better. A similar reported case could be solved that way (it was working perfectly on one computer but not on another, on the same network).
I still need to figure out why the server doesn’t respond in those situations (it’s in the ToDo :slight_smile:)
I have turned off all VPNs, but this phenomenon still persists
