Hi all is ti possable to extrude(pull) a simple line shape into a surface in Sketchup? I can of course in other 3d apps.
Thanks in advance Dan Martin
Yes. But give us an example of what you are having a problem with.
That’s a bit of an oxymoron isn’t it?
Not necessarily. Think of a wavy line extruded into (admittedly zero thickness) corrugated iron sheet.
You could get close with a small offset to a curve, joined at the ends with cross-lines to make a thin face, and then use the FollowMe tool to extrude the face along a path. Then if required, delete one face and the two thin edge faces.
See below most 3d apps can extrude a spline or an edge it’s great for creating things line say a corrigated roof etc. It helps to keep youy meshes clean and simple.
Da Martin
Simple, extrude by vector.
OK, My EdgeFollowMe in Aug 2011.
SketchUp does not have a specific tool to extrude edges into surfaces. I think Box is using some extension, and sdmitch apparently has an extension also - it’s hard to tell. If you find yourself performing this operation many times an extension would save you a lot of work. If not, here’s a way without using extensions:
Hi Jim,
Thanks!! I will see how many times I use the above in Sketchup. I do often extude edges in 3ds Max and find it a very usefull tool.
Dan Martin
Hi there “Box” is that a plug-in?
Dan Martin
