I need some advice on how to use the Smoove tool on a topo built from contours. I already have a solid topo.
What I’m trying to do is open the group, select the top surface I want to edit, and then apply the Smoove tool. However, when I do this, the Smoove tool selects the entire object and moves it up and down as a whole, instead of affecting only the specific points I want to adjust.
What is the correct way to use the Smoove tool in this case?
I count 24 endpoints (in yellow) for the 140 feet side. This means that the spacing between endpoints is 140’/24 or 5’ 10” between endpoints. Your 1 foot radius is quite small. Try a larger radius.
When I opened your file and activated the Smoove Tool I get a radius of around 833’. Much larger than your terrain. That would exploain why you don’t see the circle and why when you start to use the tool all of the vertices show in yellow.
I had no problem using the Smoove tool. As Dave said, select a radius proportionate to the moves you want to make. Note that in your model, if you type a number and press Enter, the number is recorded as Inches. You can change this behaviour in Model Info>Units. I used a radius of 30 feet by typing 30’ (including the feet symbol.
As long as you double click to edit it before you start using the smoove tool. But terrain doesn’t need to be a solid to use the smoove tool, I often work on flat planes in my models.
Can I have a stupid question? The order was the following: You opened the file, then you opened the group (topo) to edit it and select the Smoove tool, right? You didn’t select the top surface additionally before the smoove tool?
