Smoove tool help
HI there,
I can’t seem to use the Smoove tool successfully on an existing terrain I created from a DWG survey file. The entire terrain seems to move when I try and raise or lower using Smoove, although I set the radius to 1 or 2 metres …Help!
AM Gardens_The Garden House_3D model 1.skp (4.0 MB)
It would probably help if you subdivide the terrain more.
Use the Add Edges button on the toolbar.
The Smoove tool works on this terrain, provided it is open for editing. However the terrain divisions are not an evenly spaced grid, and some of the triangulation is in relatively large planes, turn on hidden geometry to see how the terrain is built. Smoove tool works on nodes, or the places where edges intersect, so if the nodes are further apart it limits how precise an adjustment the tool can effect. Smoove will not “bend” an existing plane.
1
Thank you ! I’m going to try both these suggestions now… will report back. Much appreciated.
Yay perfect - thank you.
