That is called z-fighting and is the result of the computer not understanding which face you want to display, so it means you have two faces fighting for the same 3d space.
You need to separate or remove one of the faces.
Sketchup doesn’t have the option like 2d software of telling one to be in front of the other.
So your floor probably has a ‘slab’ and then a floor ‘skin’ that you are trying to paint. One needs to move, get thickness, or be removed.
If you attach your model we can be more specific.
I understand what you tell me. I am a ‘Photoshop-user’, so you’re right about thinking in
layers on top of each other. 2d-3d
I’m gonna try to fix it in the way you’ve explained.
Hereby i’m attaching the SKP-file FloorProblem.skp (8.2 MB)
If you want to hide the images you’ve imported, give them a tag and turn off that tag’s visibility.
Before you get into applying materials and textures you should spend some time correcting the reversed faces. There should be no exposed blue back faces. In your model the majority of the faces are reversed, however. Painting them doesn’t fix it.
