Quads Modelling - How to get rid of triangles and pentagons?
Hi all,
I’m trying to learn quads modelling in Blender and i follow this tutorial. I wanted to add finer detail that tutor didn’t create and i came across a problem.
How can i get rid of these triangles and pentagons? It’ll be great if you could give me some tips/methods about how should i approach these issues.
Here is the .skp , .blend and .obj files : Anvil.zip (249.2 KB)
I also found these as guidance but having hard times making sense of them
Honestly, I think your model looks good enough. That’s what Blender Guru said. It’s a tough problem that doesn’t make much of a difference, so it’s not really worth your time. I think your priority should be sharpening those creases.
Watch 18:19 - 19:17 to hear what Blender Guru said about this subject verbatim. He basically said it’s fine if you have triangles and n-gons, but only if the model is sufficient.
The problem is when i want to sharpen those edges, i need to create ‘loop cuts’ and those triangles & pentagons hinders that.
The occational triangle is fine IMO.
But the n-gons is worth getting rid of. I got some links to quad modelling workflow articles here: Working with Quads — SUbD
Dang… some of the links are now dead :frowning: I need to see if I can find where they moved. They were good resources.
At least this one still works: http://topologyguides.com/
Here is one:
@thomthom Thank you, I’ve already taken a look at your website, topologyguide.com and much more. I think i’ve a fair technical knowledge about quads modelling now but need more practice.
@MikeWayzovski It’s amazing to see that what a 10 year-old video can do, explains everything perfectly, thanks for sharing.
Finished the anvil with slight deformations but will move on for now :upside_down_face:
