Hi all, recently I’ve been having a play about with sketchup as it’s something I want to learn.
I’m drawing up a workshop, and surprisingly up to now it’s actually gone really well, very intuitive free software well impressed.
I’m now stuck. Will attach some photos: Edit can only post one as I’m a new user.
Now you see this frame that the window sits in, I need to put in a rounded edge which is the white bit:
However, it needs to have 45 degree angles at each side so obviously it fits together like the wooden frame beneath it.
So I need to put a 45 degree angle in each of the positions shown with a red arrow:
The problem I’m having is the only way I know how to do this is to draw the rounded edge (21mm radius) and then draw the 45 degree line on and pull/push tool it through. This does not work as you can’t push or pull a smoothed or curved surface.
Does anyone know a way around this? I’d be very appreciative!
Cheers, Tom
