I am making my first model in sketchup pro 2018. I have drawn the contour lines with a boundary around the pond in dynascape. I cannot figure out how to push pull the contour lines so I can make elevation visible in the model. Please advise. I have uploaded a screenshot of both he dynascape drawing and the sketchup model i have thus far.
Export to SketchUp ā DynaSCAPE users will benefit from a new feature in v5.5 that will prepare and then convert your DS|Design drawings directly to SketchUp format (.skp), allowing you to open them in the free version of SketchUp.
In trying to use push/pull, nothing happens when I click on ANYTHING when I have the push/pull button enabled.
Please advise. I tried holding down control and nothing happened.
Merged with duplicate post. In the future, please limit your questions to a single post⦠posting the same question multiple times will not get it answered any sooner.
Just to make a few likely assumptions - from your screen capture, it looks like you imported contour lines, not a terrain.
If so, you would need to create a terrain before you can edit it.
I donāt have experience with the other app as @john_drivenupthewall does, so my assumptions may be off, but in general you just double click (or keep clicking until you have selected lines as noted in the identity window) on the contour lines - they should be highlighted in blue, at which point you then select a sandbox tool āfrom contoursā - this will fill in the surface between the contours.
This surface is called a ātinā and can be edited/adjusted to preference.
Let us know if this is along the lines of what you need.
Instead of push pull, activate the select tool with the entity info window. Click on something you havenāt been able to pushpull and tell us what entity info says.
I apologize if that struck you as harsh. But there is a limit to what anyone can do to help you if you canāt share the file, as we are only able to guess what might be the issue. So far, guessing hasnāt workedā¦
ok - first step - you will see the entity info dialogue box in the top right corner - you need to keep an eye on that as you click on various parts of the imported model.
