Bonjour, j ai creer un composant dynamique a partir de d autre composant. pour modifier les dimensions tout fonctionnait a merveille,jusqu au moment que je le deplace… l axe du composant change de place !!! j ai eclater le composant … recommencer … modifier les axe…chaque fois que je deplace le composant les axes change de place!!!
Hello, I created a dynamic component from another component. to modify the dimensions everything worked perfectly, until I moved it… the axis of the component changes place !!! I burst the component… start over… modify the axes… each time I move the component the axes change place !!!
Thank you
Reply:
You do not need to reference the parent position, have removed them. Their position is relative to the parent axis, not the global.
